Hi Experts,
I want to get flashplayer pour blackberry.I am having pour blackberry software.I need to get a compatible version of flash player for pour blackberry.Anyone with blackberry experience can suggest me a solution.Thanks.
Jaylonomarion
How to get flash player pour blackberry ?
Hello, I am having a hard time finding a freeware adobe flash player for the black berry phone. But I know a website which gives a shareware version . When we say shareware it is a trial mode or demo which has a small span of time of use. This is to test the adobe flash player that is compatible to your black berry phone.
http://www.2000shareware.com/downloads/adobe/flash/player/pour/blackberry/curve/
Hope this will help you a lot.
Flash Player is not available in BlackBerry devices. Even Shockwave player is not supported. So there is no way you can install it on any BlackBerry mobile phones. There are websites that offers non-Flash mobile website such as https://www.youtube.com/?app=desktop which you can open using your BlackBerry browser. You may also try viewing Flash supported websites on some browsers such as Opera Mini and Bolt as they have a very little support on running Flash contents.
If you have a BlackBerry device and you’re wondering if you can install Adobe Flash Player, check first if you have a supported firmware or operating system. For BlackBerry 10 Smartphones and BlackBerry PlayBook tablets, Adobe Flash content is supported. But for BlackBerry Smartphones with BlackBerry 7.1 and earlier operating system, unfortunately it doesn’t support Adobe Flash content.
Adobe Flash Player or Adobe Flash is disabled by default on BlackBerry 10 Smartphones with BlackBerry OS version 10.2.1 and 10.3.0. To use Adobe Flash, you need to enable it. To enable Adobe Flash on your BlackBerry, click Browser then go to “Menu”, “Settings”, and then “Display and Actions”. Toggle “Adobe Flash” to “On”. And that’s it. Adobe Flash is now activated on your device.
On the other hand, if you have a BlackBerry 10 Smartphone with BlackBerry OS version 10.3.1, sad news is this version doesn’t include Adobe Flash. According to BlackBerry, Adobe Flash will no longer be supported from BlackBerry 10.3.1 onwards. For more information, please refer to Adobe Flash Support Not Included.
