Hi Experts,
I am having MS Word 2007 and I have typed a letter with Arial font. I need to make font narrow and dotted. I tried to achieve this using font tab but could not find the proper place for this change. Can anyone give me guidance? Thanks.
Kierstenrhiannon
How to get font narrow and dotted?
Hello Kierstenrhiannon;
I suggest you follow these steps to change the font in your Microsoft Word 2007 document:
Create a new document based on the normal template by clicking NEW on the NEW DOCUMENT task pane>>BLANK DOCUMENT>>CREATE;
Proceed to click FONT group and click FONTS;
In the FONT dialog box, you select the font, point size and any other attributes you need and the click DEFAULT.
When you receive this pop-up message:
“Do you want to change the default font to font name?
This change will affect all new documents based on the NORMAL template.”
Click YES. SAVE ALL in the customarized Quick Access Toolbar.
Briefly but a quick one, you can watch the video
I hope this helps.
Best Research,
Chacho Terrado
Kierstenrhiannon,
In order to change the font on your document as you know you go to: Format>font and you will see the list that Word has preloaded. To get, however, "dot" formats I have included a site in which you can download "dot" formats: https://www.discoverfonts.com/font-categories/dotted.aspx.
