How to get a free adobe smart player download? There are so many flash player over the internet but I like to chose this one. Before I start the downloading process I would like to know all the compatibility and packages needed for a successful installation process. I hope you can give me the best solution for this problem.
Thank you.
To download a free adobe smart player you need to log in to
http://www.adobe.com/products/flashplayer.html
The latest version of this application is 11.03.4. on the adobe website you can see the product as your system support. Go there and choose your desired application.
And then click to download option. Here I have attached some screenshots for you.
Hope it will be more helpful to you.
