Hello experts,
How to get a free download for chrome speed booster?
A privacy tool protector and it is needed for each of the Google chrome browser it speeds up and make it more possible on browsing.
I hope you can give me the best solution for this issue and guide me on the installation process.
Thank you.
Hey Anthony Wendy,
I believe you must have to apply some tweaks to get good Browser speeds because it is a matter of a few things the collaboration of which gives you good browsing speeds e. g., Initial delay, DNS management, TCP connections. If you are having good internet connection usually more than 2 Mbps downloading speed, this should give you good speeds at browsing as well.
I suggest you to apply these issues only if you have a good connection but still you don't get good speeds. If you have slow connection, usually less than 1 Mbps, you should try any other browser with lowest capabilities to launch objects like flash, java etc.
If you want good speeds at YouTube and other video streaming websites. Download By WiFi Video Streaming Down loader.
As far as privacy is concerned, you should download a tool named Chrome Privacy Protector v1.10
