Hello experts,
How to get a free download for code 128 font? I am looking and collecting any kinds of font but I badly needed this code 128 font. I hope you can give me the best and secure download so that there are no malicious ware data that can enter my computer system. I hope you can help me.
Thank you.
You can go to this site https://www.dafont.com/code-128.font and then hit the Download button on the upper right side. Save it on your C:/>Documents and settings. Extract the file and if you want to add this font to your MS Word, just go to Control Panel and then select fonts. Hit the Font icon to view the entire fonts on your computer. Select File and then Install new font.
A pop up window will open, select the Folders and then hit the C:/>Documents and Settings. Select the code 128 font.
You can download many fonts from the following sites and these are free from malware. But just to be sure, scan them for viruses before installation;
