Hello experts,
How to get a free download for first aid desktop icons? I want to change some icons for my folder with first aid icon so that I will be able to know and easily identify the files stored on the specific folder in my desktop, less hassle. I am hoping that you will recommend a website which is virus free.
Thank you.
Hello Good day,
There is a site on the internet where you can choose different types of icons. For your question, they have a medical set consisting of 28 icons including first aid icons. These are totally free and safe to download. In other cases, there are others that are for commercial use.
You may also try this site for they have a variety of icons which also includes first aid icons. This is also safe and free to download.
Hello Madison,
I provided you a link below with a list of first aid icons.
Choose which one you like and then download it.
Right click the folder. Then Properties.
Go to Customize and then change icon.
Browse on your downloaded icon then Apply then Ok.
Hope this helped you!
Google image search is the best way to get what you need. Type first aid on Google search and click on Images in the top menu. You’ll find thousands of relevant images. If you do not like to search much considering virus infections i'll provide you a direct link to a web site then you can download free icon sets from them.
Thanks
