Angela King
10 points
Posted on - 10/12/2012
Hello experts,
How to get a free download good birthday message? I would like to send my friend an email birthday message. I want it to be nice so I am planning on downloading some samples from the internet , can you help me to get a secure download? Your suggestion will be a great help. Thank you.
Dana Cua
5 points
amy pete
Hi Angela,
That's sweet of you. You can check http://www.123greetings.com/ where you can send your friend a live greeting card. You can choose from numerous greeting cards, and you can also customize it before sending it to your friend. You can choose a background music and effects based on your friend's mood, type as much message as you want, set when to send it, get notification once your friend has viewed it and use an advanced text editor. Here's an example of a greeting card http://www.123greetings.com/birthday/birthday_wishes/wishes138.html.
Hope this helps.
Hi angela.
Here are some links for a good birthday message.
1. Use this link: www.groupcard.com
2. SELECT A CARD of your choice, there are samples as you open the website. If it is for a girl or a boy.
3. Click the card that you want and then you will be going to the next step and that is to SIGN THE CARD.
4. Put all the details:Â
Who is this card for?
Enter your message
You can change the font and the color.
5. You can also put a photo of yours.
6. Put the email or facebook whom you will give it and also the date.Â
Who are you giving this card to?
And then click continue.
7. You can also ask your friends to put their message on the birthday card. Just send them the link you created.
Hope this would help.
