Hello Experts,
How to get a free download for keepalive utility? I think this is the tool that I am looking for to keep your internet connection strong and more reliable. Is this really the way a keepalive utility tool act? I hope you can give me some more idea on how is this utility tool working.
Thank you.
Hi Madison,
How are you?
Keepalive utility allows the user to monitor the running applications in the PC. There are many internet sites that offer keepalive utility for free. I have searched some of those, and there are also some that are in trial version for 15 days.
Here are the links that will provide you free download of the said utility:
Here is the link for the trial version.
Hope this helps.
All the best,
Diane
Yes, this helps to keep your connection alive. You should follow the step given below,
Go to CNET download.com and then press the Download Now button to download. Press run or save button.
Hi Madison,
How are you?
Hope this helps.
All the best,
Diane
