Hello guys,
How to get a free download for nemesis bluetooth? This is all about remote access; I want to access the computer using a mobile phone with bluetooth or other kind of bluetooth device that is related to this. I hope you can give me the best website to download a secure application, thanks.
Hi Stephen,
You can go get LogMeIn. It's a free program that you can use to access your computer with your mobile phone. You need to create an account on their website to be able to download the program. Although, you want a program that can access your computer using a Bluetooth. True, you can transfer files from your phone to your computer, but to access and work on your computer, I would suggest a different method.
Try using LogMeIn. If it doesn't work for you, you can check out these websites that proposes the use of VPN, wherein you can access your computer with your phone virtually anywhere. Your choice:
