Hello guys,
How to get a free download for pc sync manager 2010? For additional information; my current operating system is windows XP which has a 2.1 GHz speed of processor and I want to know all the requirements needed for this kind of application. Compatibility and security measures are also included.
You can get free pc sync manager from HERE. You will be navigate to website click on download as per below image.
Save it to PC. Now unzip it using WinZip software. Then click on .EXE file this will start setup. After successful installation you can use it.
Your system requirement is ample to run this software.
Hey. Allison Davy,
To the best of my knowledge your current operating system is windows XP which has a 2.1 GHz. Well regarding your system requirement you can download from a list of pc sync manager from Sync manager.
Kindly give a try to third last as it will lead to few good choices .As per you system requirements it will work good.
I hope that this will fix your problem.
Thanks & Regards
Gillam Janetj
