Mia Molly
20 points
Posted on - 09/26/2012
How to get a free download of the top command iPhone? This is a monitoring tool that gives the update about the CPU and processor security and problem. I need this kind of application for my iPhone I hope it is compatible with all the feature that can possibly reflect. I hope you can help me guys.
Thank you.
How to get a free download of top command iPhone?
Top command is not yet developed for iPhone, but if you need processor monitoring tools you can download system status app from the app store.
If processor security is your concern or you're testing your phone if it is possible to be compromised yes it can be compromised as it can be jailbroken or the system files will be open for editing by users like us by using jailbreaking tools available over the internet. But it cannot be done over the air or remotely it needs to be connected to the computer & done by the user to be jailbroken.
I hope this helps
Thank you
