Ava larry
10 points
Posted on - 10/16/2012
Hello experts,
How to get free download for Toshiba HD graphics driver? A high definition graphics is very important especially to laptop and other desktop computers, in my case I am using a Toshiba laptop with a windows 7 starter operating system. Please give me some tips on how to get a free driver.
Thank you.
How to get free download for Toshiba hd graphics driver?
If you want to download the Toshiba HD graphic driver for free, you can do so here:
http://www.toshiba.eu/support/drivers/
This should solve your problem.
Thank you.
tazwar11
Hello Ava,
You can download you Intel HD graphics driver from link below:
Then follow the steps below:
1. Select the product type. You should select NOTEBOOK.
2. Select your product family. For example: satellite, satellite PRO, etc.
3. Select your product family series. For example: Satellite A series, Satellite c series, etc.
4. Select your model number. You can find it under the battery.
5. Select the short model number. You can also find it under the battery.
6. Select your operating system. You should choose Windows 7 32-bit or 64-bit. You can find it out by right clicking Computer on the desktop and selecting Properties from the drop-down menu.
7. Select your driver type. You should choose Display driver.
8. Select the country you are residing in.
9. Select your preferred language.
10. Click "Search".
11. Select Download to begin downloading.
I hope this solves your problem.
Indeed, a graphics driver is an essential software in a computer; however, downloading a random graphics HD driver won't be much of a help. It is because every video card has a corresponding graphics driver; thus, installing a random one would instead corrupt the system, and would make your graphics card somehow irrelevant. The drivers are after all the brain of its physical component; commanding a different component would only corrupt the whole computer.
Instead of giving you a direct link of a HD graphics driver download, I would like to suggest downloading Device Doctor. Since we do not know your graphics card, you should try Device Doctor. It is an absolutely free tool which will search all of your needed drivers including your graphics driver. Not only will it search for the essential drivers, but it will also update your drivers automatically.
Here is a link of the Device Doctor download:
http://devicedoctor.com/
Just fill up the form, and you are good to go. Don't worry I've tried it already.
ITPro
If you need to find any driver I highly recommend below mentioned website. it has a large drivers database and it allow you to detect your configuration and missing drivers as well, also he will suggest some drivers update to download if you want to.
As an IT support I find it very useful to me and I was using it for a long time and I find in it all what I need, however even if is in French language is still easy to use and to get what you ask for.
Here are the steps to download your drivers:
1. Go to https://www.touslesdrivers.com/.
2. Click on "Mes Drivers".
3. Scroll down the page and click on "Lancer la détection".
4. It will ask you to install a plug-in, go ahead and install it.
5. After finishing the installation, click again on the "Detector maintenance".
6. Wait some seconds and he will give you the list of your drivers with the links to update the outdated currently installed drivers also the missing ones.
7. Click on the link what you need, a popup windows will open to give some suggestions of sites look first for the constructor link if not then from the site drivers database.
For more help please find attached the steps to download your driver:
Yes graphic drivers are very essentials for your pcs and laptops, if you are using Toshiba laptop and want to install graphic drivers then you may have to follow following links to download your desired graphic drivers for free:
