How to get free download ts client 55 for win XP? I want to use a remote desktop connection that will be able to manipulate the works on the other computer for more work to be done I can also use this kind of application in most businesses. It is great and convenient. I am using windows XP operating system.
Thank you.
How to get free download ts client 55 for win xp?
Hello Shannon,
You can get the client 55 apps for windows XP from the internet. You just need to search with the right system specifications and then download it and install it on your computer. As for the convenience, the application will make accessing and manipulating your work from a remote computer a lot easier.
Nicke
Hello Shannon,
Remote Desktop Connection is a great feature when we needed to access a remote computer. You can access all the applications in your remote machine and even a network printer if you have attached any in the remote location. There are number of Remote Desktop Connection software available over the internet and as you have requested ts client55 for Windows XP I have provided the download link below.
Download Terminal Service client for Windows XP
Also you can download the new version which includes more features.
Download Terminal Service 6.0Â
Thank you.
Rubi Sharlen
