Hello experts,
How to get a free sample template PHP statistic? Or any other related PHP static code samples from the internet will do. I just want to get some reference to study with in any form, PDF, Microsoft word, Microsoft excel or anything that will be downloaded from the internet so that I can study it without internet connection. I hope you hear my concern.
Thank you.
How to get a free sample template php statistic?
I have browsed some website that will help you get a reference with regards to your studies. Some templates were specialized depending on the kind of statistics you are going to have.
You can have those studies on the sites provided below. These are compatible in both Mac and Windows.
Hope this helps you.
Diane
Hello Dborah,
Your problem is easy to solve, if you think for a moment to get it you will be able to get it easily. You can go to the link below to get huge collection of free templates for PHP.
http://www.linkedin.com/in/dreamtemplatestudio
Thanks
