How to get free scheduler studio net 2010? Just like an organizer wherein I can enter all the important events. I really need it because I am kind a busy person and this will be a great help for me. I hope you will give me any suggestions.
Thank you
Hey,
I will recommend you to download and Scheduler.NET to resolve your problem. It is a component library that provides a set of calendar and scheduling features. It is similar to Microsoft Outlook, you can get it from following link
Download Scheduler.NET
File size: 8.60 MB
Version: 1.1
System: Windows 2003/2008 Server/2000/XP/Vista/7
Requirements: NET Framework 2.0 – 4.0; Microsoft Visual Studio.NET 2005, 2008, 2010.
Hello Hunter,
You can also try the Quartz Enterprise Scheduler .NET. This is user-friendly and easy to use job scheduling tool. It includes many enterprise-class features, such as JTA transactions and clustering, Scheduler Job Detail Trigger Job Data Map. You can check it out and download this software on this website: https://sourceforge.net/projects/quartznet/?source=navbar
Hope this helps.
Good Day Hunter,
You can check and click the following links if you want to try much more simple or online scheduler. If you are interested in online scheduler you can try this link https://www.supersaas.com/. It is totally free but if you want to upgrade you need to pay some cash. The advantage of online scheduler is that you don’t have to waste your time installing the software, just go to the site and it’s there. The only disadvantage is that you can’t use it if you don’t have an internet connection. Hope I help you.
Some free scheduler software you also want to check:
· https://www.acuityscheduling.com/
· http://www.scheduleview.com/
