How to get free software webcam cctv?
Hello experts,
How to get free software webcam CCTV? Or is there a way we can download it from the internet for I will have to study all the functions that a software of a CCTV has. I was very interested on how it works and how did they make it along the way. I just need some information I hope you can help me.
Thank you.
Best Answer by Dawn Andarson
Answered By 5 points N/A #165363
Hi Christine,
Browsing the internet is a one-way solution in finding the right free software for webcam CCTV. The web CCTV allows you to monitor the day to day actions and transactions of a certain place you are concerned with. Here are some of the links where you can have a free download of the software for your Web CCTV Camera:
Each links will provide you the necessary steps to undertake in the process of installing. I hope it will work out.
All the best,
Dawn
Answered By 25 points N/A #165362
Hello Christine! Good Day,
There are a lot of free/open source CCTV software all over the web (Try to search it in http://download.cnet.com/windows/). They also came for different versions, for Windows (XP and Windows 7), for iOS, for Linux and etc.
Feel free to check this site for more information and for downloads:
Hope it helps.
Answered By 0 points N/A #165364
Hello Christine,
CCTV is used for surveillance. Bank or important institutes have CCTV networks to diminish the need for financial security. Prison use CCTV for monitoring behavior from a central location in addition to regular patrols. Video taken with CCTV can be recorded and reviewed later. You can get it from:
Answered By 0 points N/A #165366
You can get a lot of apps for this CCTV, apps like:
  • Axis IP Cameras
  • Mobotix IP Cameras
  • LinkSys IP Cameras
  • Cisco IP Cameras
  • StarDot IP Cameras
  • D-Link IP Cameras
  • Panasonic IP Cameras
  • Brickcom IP Cameras
And so on are some of the best apps that you can have for your ip cctv cameras.
