I have two computers for my children, one of them is Windows and other one is Windows XP both run with free AVG. So far, they are both good, respectively, no problem. Then, I just bought a new one for my own but it is on Windows Vista. Because I know AVG is safe I also downloaded the free AVG in my Windows Vista but suddenly I couldn't open it and couldn't save it.
Is it not functioning at Vista? Will you give me any source to get the free download or what do I really need to do with it ?
How to get free version of AVG Anti virus?
If you have installed the AVG Antivirus using the same installation file used in the other two computers then the problem can be due to that, because it may not be supporting the Windows Vista operating system. You can download the latest version of the free AVG Antivirus from the internet and install it on your computer. Before installing the new version you can uninstall the old version of the Antivirus. For uninstalling the Antivirus you can click on the start button of your computer and then you can select the control panel. You can then select programs and features from the available options, there you can see the list of all the programs installed on your computer ,you can select AVG antivirus from the list and then you can click the uninstall option, this will uninstall the AVG Antivirus from your computer.
After uninstalling the Antivirus you can restart your computer to make effect the changes. Then you can install the new version of the Antivirus by double clicking on the installation file that you have downloaded from the internet. After installing the new version you can check whether the Antivirus is working properly. While downloading please make sure that the version you are downloading is compatible with Windows Vista.
You can also try to update the current installation to make it compatible with Windows Vista. For updating your Antivirus you can open the user interface of the AVG Antivirus and select the update option to update it. AVG Antivirus can be freely downloaded from the AVG website. If after installing the new version of AVG Antivirus , if it is not working you can try some other free Antivirus software. I think the Windows Vista security center does not support the AVG Antivirus so better you may try to update the Antivirus or try using a better Antivirus.
You can check on the website of the AVG whether it is compatible with the Windows vista operating system. You can also contact the support of AVG Antivirus and submit the issue. If AVG is not compatible you can try with other free Antivirus such as Avast. It is a good Antivirus and can be freely downloaded from the website of Avast. You can visit the website of Avast and download the latest version of Avast. Then you can install it on your computer. I think Avast Antivirus is compatible with Windows Vista, so it will work properly. Please make sure that the version you are downloading is compatible with the Vista operating system.
You may also try to update the vista operating system on your computer, because some times Windows would have made the solution so updating your operating system may some times solve the issue. For updating your operating system you can select the start button and then you can select the control panel. Then from the control panel you can select the Windows update. There you will find the option to check for updates. You can select that and when it shows the available updates you can click the install updates.
You can download free AVG antivirus from with website https://filehippo.com/download_avg-antivirus-free/. Here you will find all old versions for this software as well. Just Click right side download button for the latest version.
