Hello experts,
How to get free WiFi application for Nokia 2600 classic? I just wonder if the Nokia 2600 classic is supported with a WiFi internet connection? Tell me more about this WiFi application for Nokia 2600 classic and how to get or apply it on the mobile phone. But if it is already applied then how to set up and connect to a wireless connection? I need your suggestions.
Thank you.
How to get free wifi application for nokia 2600 classic?
Hi Allison,
I'm sorry but the Nokia 2600 classic phone does not come with the WiFi facility. So there is literally no software for the phone to run WiFi. You can check the following link for the full specification of the phone and you can notice the WLAN option says no. Means there is no wifi in this phone.
Hi Allison!
Don’t bother because Nokia 2600is compatible with a WiFi internet connection. But, obviously you can have WiFi in the place where it is a WiFi area. You can download free WiFi application on this site.
This site also teaches you in successful downloading.
