How to get free wma editor Microsoft?
Hello experts,
How to get free WMA editor Microsoft? I want a secure one that is why I am choosing applications or software from Microsoft; I am having a hard time of finding the right one. I hope this time you’ll share with me your ideas and opinions.
Thank you.
Best Answer by Mabel Gia
Answered By 0 points N/A #165864
Hello Hernandez,
I hope you are well known to WMA editor, I think Microsoft is the best but you sometimes best thing suffer most. Besides this I will suggest you to use other software from
http://www.softoxi.com/free-wma-cutter-and-editor.html
You can use it and may get satisfaction using it properly.
Thanks
Answered By 0 points N/A #165863
Choosing Microsoft is the best, as it comes with many easy user friendly features that you will find handy to use. There are always updates available online to download for your already installed editor, therefore you never have to worry about your software getting outdated. I have two links I can recommend to you to download. They are free downloads, secure and genuine. Here are the links,
https://support.microsoft.com/en-us/products/windows
http://www.softpedia.com/get/Multimedia/Audio/Audio-Editors-Recorders/Free-WMA-Cutter-and-Editor.shtml
Hope i have been of help.
Answered By 590495 points N/A #309653
If you want to edit WMA audio files, you can try Sound Editor. It supports Windows 10 both 32-bit and 64-bit. Among its features include:
  • Load or open MP3 (.mp3), WAV (.wav), and WMA (.wma) files.
  • Save MP3 (.mp3), WAV (.wav), and WMA (.wma) files.
  • View, copy, trim, cut, and paste samples between files.
  • Play and loop from anywhere in your file.
  • Remix tracks.
  • Convert popular audio formats.
  • Multi-step undo.
Another application that allows you to open and edit WMA files is Cool Edit Pro 2. It supports Windows 98, Windows 98 Second Edition, Windows Millennium, Windows 2000, and Windows XP.
