Hope everyone safe and sound.
I need a tips on how to get the updated version of all my drivers. No need to check individually, just go through and get latest updated version. Where can I download and keep my PC updated?
This is very important for me. Please any one help me. ASAP.
Thank You.
kimanif
How to get Hardware updates driver automatic
For your computer to update drivers automatically, you need to have a good internet connection and you must turn on the Automatic updates settings.
To turn on automatic updates follow the following procedures:
Go start menu / control panel / security center. After click the security center its windows appear.
Look at the bottom and you will see a heading “Manage security settings for”
Under that heading click Automatic updates. A pane for automatic update appears. Select the first option then set the schedule. The schedule can be everyday or a certain day of the week at specified time. This setting downloads the drivers and installs them on the specified day and time.
lee hung
75 points
Go to the start menu;
Open control panel and then select the Windows update and click;
Select check update in the windows update;
Now routinely download the latest version in your system and wait for an hour to finish the update.
Then simply mechanically install the new version of the software in your computer.
Now restart your computer.
After that go to control panel again and select windows update to obtain the software.
To update your computer always check the windows update.
