How to get internet calendar feed outlook 2011 mac?
I am using windows 7 64 bit operating system before when the last time I try using outlook 2011 version, but now that I switch to mac operating system I don’t know if it is still compatible.
Can you give me some advice?
Thank you.
How to get internet calendar feed outlook 2011 Mac?
Hello Mellisa,
Some Software may work on a windows system and still work on a mac system, but it good to just check the specs of the software to be sure about that.
Try installing it on the Mac PC and if it refuses, you can just go ahead and then download a version that is meant specifically for mac.
Nicke
Hi Mellisa Wright,
 I have reviewed your issue and find the best solution related to your issue for internet calendar feed outlook 2011 on mac.
I suggest you can configure the calendar feeds for outlook 2011 on Mac with the help of SPIKE.
For more information for configure the calendar feeds for outlook 2011 on Mac. Please visit this URL;
I wish this solution may be helpful.
Thanks!
Fenster Maxine
