Pam Lendrum
10 points
Posted on - 03/25/2013
Hi, There's a lot of talking about this iOS 6.1 bugs. I admit I am not so much familiar to updates from Apple software and without any knowledge of knowing this bugs. I want to be aware and want to experience what's going on with these updates, can anyone tell me how to get ios 6.1? Thanks a lot.
How to get IOS 6.1 for my iPhone 5?
Pam
Apple will not release a software update, if it is full of bugs.
If you would like to update your Iphone, simply go to General setting of you Iphone and click on update. Update will then be done over the air.
Alternatively you can connect you Phone to your notebook, via the cable provided, and do the update through Itunes
Either way, the data, and time used will be equal.
