How to get ip address
How to change IP address everyday?
If i restart my router and my system will my IP address change everyday?
When you restart your router and/or restart your system, your ip address change almost every time you login. I say “almost” because when you restart your system, if your “old” ip address has not given to another device, DHCP (Dynamic Host Configuration Protocol) will give you that ip address. Ifyour “old” ip address has given to another device, it will give you a new ip address.
Another way to change ip address without restart system: start > run > [type] cmd (to open command line) > [type] ipconfig /release [enter]> [type] ipconfig /renew [enter]
Hope this helps
Notifications
