How to get the latest drivers 9530 blackberry storm USB ?
I am looking for the latest version of "drivers 9530" blackberry storm USB. But unfortunately I didn't find it. Can anyone help me? I will be grateful to him.
The 9539 BlackBerry software can be found at:
https://swdownloads.blackberry.com/Downloads/entry.do?code=6C3CF77D52820CD0FE646D38BC2145CA
Installation method:
1. First you must download both the desktop and handheld driver software on your PC.
2. Ensure you install the desktop software first then the handheld to your PC.The handheld software will update the software on your BlackBerry wireless.
Hi Shawon,
As I reviewed your issue, you are looking for your blackberry storm 9530 USB drivers.
You can install BlackBerry storm 9530 USB drivers, Please follow the following steps:
1. You can download BlackBerry Storm 9530 USB drivers from the mentioned link : http://blackberry.supportscentre.com/blackberry-storm-9530-pc-suite-sync-usb-driver-download.html
2. Here you find “BlackBerry Desktop Software v7.1” for downloading drivers.
3. Click on that link and download the drivers, then install.
Enjoy blackberry Storm 9530 PC Suite.
I wish this solution may be helpful. Thanks!
Best,
Fenster Maxine
The BlackBerry Storm 9530 Smartphone is a 3G device operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on September 2008 and released on November 2008. Unfortunately, this BlackBerry model is no longer in circulation and has been discontinued. It measures 112.5 x 62.2 x 14 millimeters and weighs 155 grams. It uses a mini-SIM card.
It has a TFT capacitive touchscreen display with 65K colors at 360 x 480 pixels screen resolution. It runs on BlackBerry OS 5.0.0.419 powered by Qualcomm MSM7600 chipset, 528 MHz ARM 11 processor, and Adreno 130 GPU. It supports microSD expandable up to 16 GB. It runs on 128 MB RAM with 192 MB ROM and 1 GB internal storage.
The primary camera supports 3.15 megapixels with LED flash and autofocus. The primary camera features geo-tagging and can record video in 320p. It doesn’t have a secondary camera though. It has 3.5-millimeter jack; Bluetooth 2.0 with A2DP; GPS with A-GPS; and microUSB 2.0. It doesn’t support WLAN and radio. It has built-in accelerometer sensor. The pre-installed web browser supports HTML. Java is supported.
It runs on a removable Li-Ion 1400 mAh battery with standby time up to 360 hours and talk time up to 5 hours and 30 minutes. It is available in black color only. If you need drivers for your BlackBerry Storm 9530 Smartphone, you don’t need to literally download it manually. Just install the BlackBerry Desktop Software and the drivers will be automatically installed on your computer.
Important notice from BlackBerry: they will no longer be providing updates as well as security updates for the BlackBerry Desktop Software. They said the download will still be available but technical support will no longer be provided.
If you’ve been using the BlackBerry Desktop Manager with no problems whatsoever, you can continue using it but BlackBerry will no longer be providing updates to fix problems or security issues or add features.
