Any Hill
30 points
Posted on - 10/20/2012
Hello experts,
How to get licensed download image of motherboard?
I need it for my webpage project, I will get some piece of the motherboard pictures and edit it in a Photoshop.
The finish product will be uploaded as a banner for my new webpage creation.
I hope you can give some advice.
Thank you.
How to get licensed download image of mother board?
Hello Any,
You can get the licensed images of the motherboard from quite a number of sites from the internet.
All you will need to do is search for it.
You can as well choose to use the free ones that are for public distribution, or just use a camera to take pictures or motherboard personally.
Nicke
If you need licensed and high resolution images of motherboard you can connect to the link and make your choice from thousands of available motherboard photographs.
