How to get a licensed icon creator freeware?
Hello experts,
How to get a licensed icon creator freeware? I need to create my own icon for my different important folders in my laptop with an operating system of windows 7 64 bits. The last time I tried to download was unsuccessful and not secured; I hope you can give me a safe and licensed software. Thank you.
Best Answer by AlfordCharisse
Answered By 0 points N/A #188662
Hello Kyle,
Well, it is not advisable to download software from just any site for some sites on the internet do not offer trusted applications. I will therefore give you some sites that I know for offering the best freeware and shareware applications:
  • CNET Downloads
  • Majorgeeks.com
Just check them out.
Nicke
Answered By 0 points N/A #188663
Hello Kyle,
You can download the icon creator freeware from many websites. Looking at your past experience of unsuccessful download. It may be due some viruses. Always update your antivirus before downloading any software. For icon creator you can visit Brothersoft website. It's safe to download a software from there.
Here is the link:
http://icon.brothersoft.com/icon-creator.html
Choose any software you like from there.
Thanks
Answered By -10 points N/A #188664
I am giving you the link to the download icon maker software, which is portable software & fully functioning. I am personally using this software. It is really very simple to use, and its handy software. Below is the link to download “Easy Icon Maker 5.0 Portable”.
I hope it will be really helpful to you.
