Trevor Jhon
40 points
Posted on - 10/19/2012
How to get a licensed key for media composer mac? I am using mac operating system and reinstall all my application due to viruses that attack my computer registry. After the reinstallation, I got this problem with media composer which is asking for an activation key which is I already forgot. Give me some ways to get a licensed one; I need this to be installed as soon as possible. Thank you.
How to get a licensed key for media composer Mac?
Hello Trevor,
You know that the program must be activated for it to be able to work, and therefore if you have forgotten the key you will just need to try harder and remember it. Or you can as well call the customer support or the supplier you bought the application from and inquire for more details.
Nicke
If you have forgotten the activation key or viruses attacks your computer and damaged your registry, we cannot do something to obtain the software again unless you will call the software' manufacturer support and ask for assistance or you can also try to insert your operating system recovery disk to fix the damaged registry files. There are product keys that are available for download but most often, these software contains viruses and other threats that might infect your computer system.
