How to get a login details download free? I think this is one way of solving a forgotten password problem and some cases that you can even remember your alternative email address. I hope this kind of software will help me to get all my possible log in information. I need your help.
I suggest you not to use any software available on the web to store your passwords. It’s very risky if an intruder could attack that software all your passwords will be on their hands so don’t do it. You can create your own version of software to store the login details if you know any programming language. If not you can simply use a excel sheet to store them but again don’t keep full login details with the same file. I think your problem can be solved very easily through a word file, Excel sheet, Note pad or a word pad you do not need to go for any kind of software.
