How to get a lotus notes design free gif?
Hello experts,
How to get a lotus notes design free gif? I am confused if I can get a free download from the internet automatically set in lotus notes when installed or I really have to do some procedures before the design will really take effect in the application? I know you can help me resolve this issue.
Thank you.
Answered By 10 points N/A #178322
Lotus notes designer is a very effective and useful software. It has many uses and can be used in many formats of images. You can design wallpapers, cartoons, backgrounds, etc. Using Lotus designer. It is a free software and can be downloaded from the IBM website.
Before you download the software make sure you check the compatibility with your system. Check the system requirements of the software and then compare it with your system hardware. If your system does not meet the system requirements then the software will not work on your computer. So download the version that is compatible with your system.
You can download Lotus designer here – https://www.ibm.com/developerworks/downloads/ls/dominodesigner/. Save the setup file to the desktop and install it on your computer.
