Hi guys,
I found that Evernote is pretty good to use and very business friendly as we can save our emails and all important data in it the can access our saved data from any where and on any device. So I want to get my Evernote address or link so that whenever I want to send my important data to Evernote it should be easy to me to access the data. So please tell me how to get my Evernote link address.
How to get my Evernote email ID or address?
How are you? You should take different initiative to activate Evernote email address for different operating systems.
For Windows:
Step 1: firstly you should click on “Tools” option.
Step 2 : Finally you should enter into “Account Info” option. Then your e-mail address will appear just after "Email notes to". That’s exactly it.
For Mac :
Step 1: Firstly, you should click on your username.
Step 2 : Finally you should enter into “Account Info” option. Then your e-mail address will appear just underneath "Email notes to". That’s exactly it.
IPhone, iPad, and iPod Touch :
Step 1 : Firstly strike username so that you can enter into your account Settings.
Step 2 : Secondly Scroll down and select “General” option.
Step 3 : Finally you can find and get your Evernote Email Address.
For Android:
Step 1 : Firstly Strike Evernote menu.
Step 2 : Select Settings.
Step 3: Scroll down until you observe and enter into the Evernote email address. Learn more.
Moreen Jamnelly.
