How to get my Google plus profile back on Blogger?
Hi guys,
I want to ask a question and that is how o get back my Google plus profile visible on blogger blog. Some while ago I deleted my Google plus profile on my blog but now I want to get that back so please help me and give me step by step details how to get my profile back on blogger blog. Thanks.
Answered By 10 points N/A #187007
How are you? You should set up the following steps to solve your problem:
Step 1 : Enter into Blogger dashboard.
Step 2 : Click on Google+tab option. If your blogs are related to Google-profile, a new “Use Google+Comments” setting will be appearing on the “Google+tab” option.
Step 3 : Check the box next to the setting to start with “Google+Comments”.
Step 4 : You should select “Use Google+Comments”. Then unhide “posts and comments” option under “Setting” option.
Step 5 : In the post editor, under “Options” menu, Reader comments are set to “Allow”.
That’s it exactly. Learn more.
Moreen Jamnelly.
