How to get new ios updates
I have been using iPhone 4s which having ios 4 version but now I want to upgrade to latest available ios versions please suggest how to get new ios updates for my iPhone 4s
Apple has a very systematic and easy-to-follow sequence of steps at their official website that you need to take in order to upgrade your iOS. Since your current version is iOS 4, this is the link that you need to follow carefully. https://support.apple.com/en-us/HT204204
The procedure asks you to take precaution by taking backup of your personal stuff with iTunes. After that, the procedure splits into 2 branches; one for the scenario concerning an individual who does not normally sync the device and the other for one who does sync the device. Please make sure you take the one that is appropriate for you.
Hope it helps. Good luck.
Best Regards
Parisi
