How to get new Skype version for java enable mobile?
I am using java enable Nokia mobile phone. Unfortunately,I have lost my manual.
Now I want to download the new Skype version for java enable mobile phones and installed it.
Please help me by giving instructions of this app.
Answered By 0 points N/A #193359
Hi Ria,
Though Skype is available only for Android, Windows, and Bada 2.1, there are some handlers available for java, you can give it a try but the only problem is it doesn't support full functioning in java as there is o such version developed yet.
You'll only be able to send and receive messages and won't be able to make calls in the java version of Skype.
Anyway if you want to try it out, you  can download it from this link
Cheers!
