How to get notepad on windows 8
Asked By 130 points N/A Posted on -
I have a question, and I just caught this instant you can answer the situation. I credited a new mainframe and for the uncertainty of me, I cannot find the Notepad program! I use the situation all the spells, but I can’t digit out how to load the situation on Windows 8.
Can you help me catch my Notepad?
Answered By 5 points N/A #185257
Move the mouse over “Start” button and then move it to the left, bottom corner.  This action will open up the short menu. (Buttons from the top down are: “Settings”, “Devices”, “Share” and “Search”.
Click on the Apps button on the bottom and a list of all the installed applications and apps will appear in alphabetical order.  Notepad appears in the list. You can also pin it to the start page or task bar.
Answered By 0 points N/A #185258
Microsoft improved about everything but the weather when they sat down to strategy the Windows 8 user interface, and that take version of the way you find and load many common Windows through situations. Here’s pardon you must do in order near load Notepad:
1 – Make sure the Start Screen is overburdened (this is the screen that contains all those shiny new tiles), then simply start typing the word notepad. You’ll see a link labeled “Notepad” equalled up over on the left-hand side of the screen. Click the situation and the notepad through the condition you will open up.
2 – Later you’re going to be using Notepad a lot, I commend “pinning” the situation toward the Start Screen. Redo step 1 toward display the relation again, then right-click on the situation. You’ll see  a  panel open at the low ward of the screen, and you can pin the situation there.
