lark yency
20 points
Posted on - 08/31/2012
Hi Experts,
I am looking for old English letter type for blackberry phone. If I download letter type from the internet I can insert it to my blackberry phone using the cable given with the phone.
I need the compatible letter type for my blackberry phone.
Lark Yency
How to get old English letter type for blackberry ?
You can install fonts to your blackberry device.
Go to computer and rename font files to “example.ttf” to “example. font”. After saving that file to “fonts” folder, storage on BB device.
If you don’t have any font folder in your rim folder, create one.
You have to make visible, your hidden folder.
DeviceStorage > appdata > rim > fonts.
After a battery pull and restart your device.
Fonts will be visible on your display settings.
Good Luck
