JEFFREY
200 points
Posted on - 10/30/2012
How to get an open source doc to text batch? I want to get open source software that will possibly convert doc to text batch file. I am very disappointed the last time I download one it was unsuccessful. I need licensed open source software that will let me do the conversion.
Jeffrey
Hello Ms. Jafferey,
Don't be disappointed, It is not a big issue, If you are using Mac OS then please visit the following website
https://bulkfilemerger.com/
If you want to convert a single document or many thousands, this Mac tool will do it. It convert multiple documents in seconds. It is powerful Mac utility, which convert thousands of doc files to text files.
But if you are using Windows Operating System :-
Then please visit the following website
http://convert-word-to-txt.www.software112.com
The price of this software is $18.95. Size :- 1.4 MB
Thanks very much.
