How to get the original winscp mit cisco
I have winscp mit cisco, but it seems like a fake one, maybe its broken, I try to re-install it, but no luck, How to get the original winscp mit cisco ?
Hey Nicola,
I would suggest that you try some alternative Winscp program as the program Winscp mit cisco doesn't have a stable version right now. You can download the following to programs-
1. WinSCP plugin for FAR from here-Â http://winscp-plugin-for-far.software.informer.com/Â or,
2. WINSCP_WinScp Client_Multi_4.0.6 from here- http://winscp-winscp-client-multi-4-0-6.software.informer.com/
Hope, this will help you.
Why don’t you download latest version of it now which is already released because it will work perfect and better then old one. It’s freeware software so you don’t need to worry about paying for it.
I will provide you the link.
https://www.techspot.com/downloads/1487-winscp.html
Or if you don’t want to install latest one then just upgrade the plugins it will recover all which is broken.
For example if you are using winscp 4.0 then upgrade it to winscp 4.1.8.
