How to get phone video screen capture?
Hello fellows,
How to get phone video screen capture? There are some videos in my Samsung galaxy y mobile phone and while watching I wonder if I can capture relevant scenes in the video. Share with me some ideas regarding this topic.
Thomas.
Best Answer by Thomson martin
Answered By 0 points N/A #86557
Phone video screen capture tool available in Google play go to search engine click play button on top of website then type screen cast video recorder in search bar of site then get a download link but you should open site in mobile phone and download the tool read instructions then follow installation guide and get video screen capture in files of memory.
Hope these shall helps you
Thanks
Answered By 5 points N/A #86559
Hello Thomas,
There are many ways you can capture a video on your Android phone. You can use some apps for screen recording. You may visit the link below for a list of trusted and efficient apps that you can use:
5 Best Android apps for screen recording
Thanks very much.
Answered By 5 points N/A #86561
Dear Thomas,
Please assure this given two files at the location System/app/:
  • ScreenCaptureService.apk
  • ScreenCaptureService.odex
After that you just need to press the home button of your mobile and then the power switch. You need to assure that the clicking process will be like mouse double click. I mean to say press them both at a time but home button first. Images are saving in the gallery
Answered By 0 points N/A #86563
Hi Thomas,
I am sending you the solution this will help you to capture screen shots in your Samsung phone
  1. Make sure SD Card present on your Galaxy Y.
  2. Navigate to the screen that you want capture.
  3. Press Home button and quickly press power on button.
  4. Then you can hear the capture sound (camera sound).
  5. Screen captured saved as image file at SD Card/Screen Capture directory.
Regards
