Hi Experts,
I am looking to get player Microsoft application for windows.
I am having windows media player inbuilt with windows but this player is more advanced.
Can it be downloaded from the Microsoft website.Let me know.
Jonathanchandler
How to get player Microsoft application ?
If you're not used to the new Windows Media Player then you will find it really complicated, But you can download the Media Player Classic that has all the basic features of WMP but is very user friendly.
To install MPC on your computer you have to download K-Lite Codec Pack at http://codecguide.com
LyanaHay
Hi Jonathan,
There are so many applications available which can play media files on your windows.
I am listing few of them here:
1. VLC Video LAN
2. Real player
3. Winamp
4. Gome player
You may find these software’s are much easier to use as compared to windows media player.
Microsoft Windows has already a built-in media player called Windows Media Player. Though you cannot uninstall it, you can update it to the latest version supported by your operating system. To check if there is an available update for your Windows Media Player, right-click a blank area on top of Windows Media Player, point to “Help”, and select “Check for Updates”.
It should bring up a dialog telling you if an update is available. Aside from the Windows Media Player, you can also install other media players on your computer like the VLC media player. The latest version supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It also supports OS X, Linux, Unix, Android, and iOS.
Another media player you can try is Media Player Classic – Home Cinema. It supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. Media Player Classic is an enormously light-weight, open source media player for Microsoft Windows.
