Jeremy Jack
30 points
Posted on - 10/09/2012
Hello Experts,
How to get QuickBooks 2009 key? The installation process will not go through without the key and I think I forgot what was the key for this. I hope you can give me some solution regarding this problem. I really need it as soon as possible, your suggestions will be a great help. Thank you.
QuickBooks is purchased through the intuit store on the web, sometimes it happens that you may lose your product key and it should have to be recovered otherwise you will not be able to run your program in future.
The solution is that you should have to run the setup of regedit, when the setup will be completed then you will find entries named as installed id and license number, license number is simply the license of your purchased product and installed id is the key for 2009 QuickBooks which you are looking for, with this you will definitely solve the problem.
Hi Jeremy,
So I guess you are able to find this information already but just in case you are still looking for the answer (which I doubt. lol) then here’s my answer.
When you purchase QuickBooks the license number of any related key should be attached to the box of the package or on the CD itself. The key is always printed on a yellow sticker.
If you can’t find the keys then call QuickBooks Support. As long as the version you are using is registered under your name then any information needed to setup your program (QuickBooks) or actually anything related to QuickBooks should be available from them.
Here’s Intuits Customer Support:
877.260.1278
5am-5pm PST
Have a nice day!
