How to get a quizmaker that works on iPad?
I need a quizmaker that works on ipad. I need it with customized and great looking. I need one on which I can control the mark for each quiz, show results with correct answers those were answered wrong, sometimes instance results upon click on each quiz. Please help me.
Answered By 45 points N/A #185607
Hello there Jeremy,
If you want some application that lets you create some quiz, I think Quiz Creator can help you with this. This application lets you create quiz using ipad and take the quiz online. You may also modify the quiz that you have entered. You may go to this site: https://ios.lisisoft.com/a/quiz-creator.html or you may want to view the list of quiz creator available on ipad: https://ios.lisisoft.com/s/quiz-creator.html .
Hope it helps you.
Regards Roland
