Hello experts,
How to get reimage license key? Reimage software is very important for our operating system for this can clean and reinstall all the damaged files. It can also scan and detect computer problems; that’s why I need this to get working as soon as possible. Can you help me how to acquire a license for my product?
Thank you.
How to get reimage license?
Reimage is a commercial software which requires you to pay for it to work, I Understand you want to cut cost but piracy is not a good day to go.
As an alternative try these:
Marcrium reflect free – you can back up your disks on a network location, DVD, and other external hard drives. is can support Microsoft's Volume shadow copy service, allowing for real time, multi version disc image.
Driveimage xml – also supports volume shadow copy & can back up disk images just like regular directories in an external hard disk storage
Paragon Drive Backup free – same as above & can also store multiple partitions from a single drive
ImageX – mostly command line tool but is best used by system admins for volume deployment.
Clonezilla – open source DOS based copy tool for windows , Linux, Mac
I hope this helps.
Thank you.
The only way to reactivate is to purchase a license.You can get it from here http://www.reimageplus.com/
