How to get remote access to ipod from pc
I am curious about getting remote access to my ipod from computer. Can I remotely access to ipod? If yes then tell me the process to do it.
Hi Mike Pincher,
I have worked on your issue and found the best solution for your issue.
I provide you a link where you can download the software to get access tap IPod from computer, the link is mentioned below:
http://www.ewe-software.de/downloads/befree4iphone-en.exe.
You download the software "Befree4ipod". After downloading when you install this software, you can create the password for security. This software make connection with the help of LAN.
For complete tutorial about how to use, View video on YouTube:
I hope it may help you. Thanks!
