How to get results of multiple searches in a website
How to get results of multiple searches enabled in a website? Is this correct? I'm not sure. But when I go with this,But it only returns the results with the order of entry.
Please help?
Please help?
Hi Jennina,
The Best you can do is you use Joomla software or WordPress. It comes with a pre-installed search module component and you can customize based on whatever criteria.
Otherwise I may recommend you use the PHP search script with which you link to your Database. If you need the script I may provide. Have I answered your question?
Thanks and all the Best.
Hello Jennina,
If you want to enable multiple search in your website then you can add a PHP script in your website. This script can get you the desired result from your search engine. Another way could be using any other software which could provide you multiple search facility. By this type of software, you will not face the hassle of using any code.
You can also try Joomla or other Word press software which has a search module and it could be customized.
I hope this helps.
Hello Jennina Yale,
If you want to enable multiple web search on your website then you need to add a PHP script in your website so that it can get you the desired result from your search engine. There is also an other option you can get it by using some of the third part software that is FusionBot. It is one of the easiest method to get your work done without any code. From the link you can get the detail and also download that one.
Notifications
