Hi there!
I am using Mozilla Firefox. I also have a lot toolbar that I've used before searching for images. But now I don't need and want to get rid of the clutter. I have deleted a lot toolbar per Firefox using add/remove program. But still it shows. Some help here please.
How to get rid of alot toolbar per firefox
To remove unwanted toolbars from Firefox, simply launch your browser and select the View option. Select Toolbars, and then untick the toolbars that you want to remove from your browser. Restart Firefox and you will see the unwanted toolbars again.
I hope this helps you.
If you wish to cover an unwanted toolbar, Launch your browser. Let's say you have Firefox, Go to View -> Toolbars menu and deselect the toolbar you would like to cover by ticking the checkbox to uncheck it (see Toolbar customization for additional information). Note: Beginning with Firefox version 4, the Menu bar is hidden by Windows 7 Vista.
All you need is pressing the ALT key to briefly show the Menu bar, then open the red -> Toolbars menu, otherwise open the orange Firefox Button menu and re-examine to the choices sub-menu to de-select the toolbars you wish to cover.
