How to get rid from animated GIF image bed bug
I have recently infected with a virus which named as animated GIF image bed bug it disturb all my image files and make it unreadable please provide how to get rid from animated GIF image bed bug is there any tool available for it or not please suggest
Answered By 5 points N/A #168732
Hi Elidal
Having a virus on your device or computer is a very annoying thing. Because it can harm your important files and it might be permanently deleted. This can also slow down your computer. There are several types of computer viruses such as Trojan Horse, Worms, Diallers and many more. So how can you remove those types of viruses? Is there a way on how to keep your files safe from virus?
  • The answer is yes. Here are steps on how to remove virus and other suspicious files on your computer or storage devices.
  • Install an antivirus on your computer. There are lots of free antivirus. I am recommending you to use Avira Antivirus.
  • Open your antivirus and run the virus scanner on the drive that you are thinking that has a virus.
  • If there are virus and suspicious files detected, move it to quarantine or delete it immediately.
I hope that the “animated GIF image bed bug” virus was removed on your device.
