How To Get Rid Of Computer Virus That Blocks Internet Access?
There is some virus that blocks the internet access of my computer. Can I reverse it instead of rebooting my PC? How can I get rid computer virus that blocks internet access?
To set your internet connection to access internet connection you can make it to recess by the following steps.
Step 1: Select internet options from start menu and open Connections tab.
Step 2: Click on the LAN Settings and change the settings as given in the below image.
Step 3: Click on the Local Area Connection in the Network and sharing centre and change the settings as given in the below image and click on OK Button  
Notifications
