How to get rid of internet connectivity issue?
I have had a problem with my wife's CPU for awhile. The brand of my wife’s CPU is Gateway GT5028. There is Microsoft windows XP installed on the computer and there is a problem in it, related to internet connectivity. The issue I have with my wife’s CPU is that the internet stopped working on her CPU.
I would love to share with you guys that before only three days it was working very fine but due to accidental power loss, it has started to get mix-up with the connectivity issue. I am not been able to get connected on that PC even for a second or two. Mean. There is zero connectivity on my wife’s computer. For this issue, I have applied different methods for the solution but none of them worked for me so far.
In this case, to fix this issue I tried reinstalled windows XP but that’s was not helpful to solve this particular issue for me. I have tried plugging-in various Ethernet cards, but it always says that “the CPU cannot detect the modem”. On the other hand, I have my CPU, playstation etc connected to the same modem and all these things work fine for my Computer. I am not sure what to try next and how to get rid of this problem quickly?
I think that any of your given advice would help. That’s why I want to know/learn from you ;How to get rid of internet connectivity issue?
I am highly frustrated by this problem but I am still very hopeful to get decent help from you guys here. I am waiting for your useful clues. I think that I may not have asked this question in as technical manners as you would love to understand easily but I still have tried my level best to get you as much closer to the issue as I can. Now, it would be your kindness if you should suggest me a solution as early as you can.
