How To Get Rid Of Pop-Ups On My Computer
Hi. Due to the pop-ups on the Window which appear now and then, I get very irritated. How to get rid of pop-ups on my computer? Please suggest a good way to remove them. Please reply ASAP. Thanks in advance.
Hi. To learn how to get rid of pop-ups on my computer, first, click on start and then select Internet Explorer and then click on tools following which select the Internet Options. Next, click on the Privacy tab. The turn on pop-up blocker needs to be turned on so that the pop-ups get blocked. Next, click on the button of settings. The sites for which you need to allow the pop-ups should be entered in the dialog box. Choose the controls to select how the pop-up blocker should work. Finally, click on Close to save the settings and then close the Internet Options box after that. Hope we helped.
