How to get rid of script errors in the browser
Asked By 130 points N/A Posted on -
How to get rid of script errors in the browser. As I need to refresh the page again and again to get the rid of the script error. I am a common user I need to do only the research work on the internet. But the script error makes me frustrated every time it’s come. Is there any way to get the rid of the script error.
Answered By 0 points N/A #186020
Yes, there is a way by which you can disable script debugging and the script error will not come again. As you are the come user not a developer, so you do not need the script debugging. Follow the procedure to disable the script debugging. Open the tools, The click on the internet option. Then go to advance and there go to the script section. It will be enabled then click to disable. And the problem will be solved. In some browser you will find the section of the script debugging in two parts you will need to disable both of them. If you will disable one the problem will be remain.
